Stsguy
- Jan 26, 2021
- 3
I'm rescuing a vintage tote goat. The lct 208cc engine (new) was originally used in a snow blower. I thought i knew.small engines ok but wow I was wrong..I need a gurus help..
The engine is a great one.. it came with a 230v elec started ice removed .being in Texas the only cold start will be if someone leaves the freezer open..
It has wires with connector that looked like it was from a stator. I used my multi meter and at idle 6volts dc 12 at full open throttle. I want to run a led head light so thought a small battery will keep the light steady and charge the battery too. However I have a feeling I need to install a voltage buck. ...regulator .. or even a rectifier.. can some one tell me whats the best and cheapest option.? Can it run less right off the stator.? Agian I'm guessing it is a stator cheers thank u joe
