Mattmotors
- Oct 10, 2011
- Threads
- 31
- 68
Sears Craftsman 917.275042 Serial 012402A00129 50" mower deck.
Here is my situation. I rebuilt the deck -spindles, pulleys and belts. I noticed that the flat idler pulley mounting bar has a little twist- bend to it causing the pulley to be cocked a little bit. Should the flat idler pulley be on the same plane with the spindle pulleys or should it be slightly cocked? Should I give the mounting bar a little lift and twist or leave well enough alone. Thanks , Matt
