LaWn GuY
- May 19, 2014
- 27
- 77
Ok first off this 12 HP flathead engine replaced my 13 HP Tecumseh, which Im currently looking for another. But anyway I don't know the history of this engine, the shop Installed It last year. It never ran quite right even when the guy drove It off the trailer and Into my driveway.
Problem 1: Doesn't run right. Adjusted carb/disassembled and cleaned. If I adjust It to run good at full throttle It runs poor at Idle and if I adjust It to run good at Idle It runs poor at full throttle.
Problem 2: When at full throttle sitting or driving without the blades engaged you can hear It misfiring. But goes away when put under load (blades engaged).
Problem 3: Change the oil a few days ago and found glitter and gray oil. New oil was gray after only 1 minute of running. Used 10W30 Castrol
Problem 4: Pulled spark plug and cranked It over and got a mild slapping/knocking noise. Will upload video If needed.
Problem 5: When restarting hot It sometimes puffs blue smoke for a second.
Engine runs fine no noises/knocking when running. Starts as soon as I turn the key. But as I said I don't know the condition/history of this engine, It runs ok, but I know It can do better. I thoroughly cleaned the carb with no change also changed fuel filter, spark plug and air filter. Even ran a higher octane with no change.
Not sure If I should rebuild this engine over the winter or what.
This engine Is pretty old around the 80's engine number 281707
