425001x8A new brake shoes, brakes dont work.
hgw1956
Put on new brake pads, still no brakes. Suggestions?
hlw49
need trans model no.
Did you make the calipier pins are free. And did you make the necessary adjustment?
Strange yopu should been to tighten down the adjustment until the disc brake locked without any brake pedal pressure.
You got both spacer rectangles in place too? Also verify the pads are .280".
hgw1956
Will double check all this.
I know the pins were seized, and the whole thing was rusted badly.
Will verify everything. Thank you.
Yes tend rust and corrode pretty bad at times. I usually ream out the pins two mounting with a 5/16 reamer and apply a little anti-seize compound.If the pins are fairly rusted I just replace them.
