That has the be a translation error.
No one runs 50 thou or 80 thou on the valve lash unless you got a blower and are using nitro.
0,5 & 0,8 mm is aboyt right or even 0.005" & 0.008" could also be right.
Yes, translation error. .005 and .008. Could be I got the int. and exh mixed up. But I don't think so. Even if, I'd still get more compression than I'm getting. I hope the head gasket is reusable. I'm thinking I'm gonna have to take the head off again.
What causes low compression?
Valves not seating properly. Possible, but not probable.
Not adjusted properly. Almost impossible because I checked them several times.
Head gasket bad. It's new
Rings gone. Impossible, because I was getting plenty of compression before removing the head.
I did loosen the PCV cover. Because there was two bolts under the fly wheel, I wasn't able to take the plate all the way off. Just loosened it to get a look at the screen under the plate. With the gasket still in position (and looking good) I snugged all the bolts back down.
