Buying Advice 42" Replacment Mower Deck
lcodd6
Hello, I have a 42" Yard Cruiser, Series 3 Mower. I have a question about trying to replace the mower deck because of rust. The deck has already been repaired from the prevoius owner and now needs more. Since this particular deck is no longer available I was wondering if there are other replacment options. Is it possble that I can retrofit a new verison?
Model: HZS15423KVE
OEM Deck Part Number: 7061958YP
Any deck can be fitted to any mower.
The only thing that varies is the amount of modifications needed to do it.
AS you still have the old deck it is simply a matter of cutting off the mounts from the old & welding onto the new.
A simple sentence that an mean a lot of work but it is doable if you have the time & a welder.
I have even seen a deck where the owner cut the mounts off with a good size lump of the deck then used that to bolt then onto a new deck .
