mzbb-6091227 sxa
As far as speed goes, I do have a tach and I'll check rpm.
I run the throttle IN the detent between the choke and fast positions to maximize speed. It doesn't seem to make a difference.
I note that the manual does not mention a throttle adjustment, as I've seen it. The adjustment they do document is the choke.
So I presumed that if the choke was sitting right, that took care of everything else.
I am cutting 1 notch from maximum height. I cut that same lawn 2 notches from the highest last week and it didn't grow excessively in between.
So not too high.
I cut at 2:30 in the afternoon, so not wet at all.
And as you indicate, it is not a big mohawk, just as you say, if you brush the lawn with your foot, the mohawk just shows up.
But it looks like hell the next morning.
I see you recommend a sharp blade edge, as opposed to many who say, a non-sharp edge.
I have to come down in the middle here: I sharpen to a sharp edge with a hand file, and as the other side notes, it's dull shortly thereafter.
And yes, mowing in 1st gear is a SLOW process.
But having to go over areas twice?
Even longer.
Again, thanks for your words. I will verify engine speed, but my manual shows no way to adjust engine speed.
