26 HP Courage SV735 stops running after mowing about 15 minutes
  • / 26 HP Courage SV735 stops running after mowing about 15 minutes
Same story as the above and again check the link for carb cleaning instruction.
If you have access to a spare fuel tank that holds an hours worth of fuel .
Hook it up to the fuel pump and see if that makes a difference.
If so then you have a blockage in the fuel cap, tank outlet or pipes.
