25hp Intek Briggs & Stratton brand new but dies when under a load. Suggestion? Thx
coachcabe
  • / 25hp Intek Briggs & Stratton brand new but dies when under a load. Suggestion? Thx
Hello, I have a John Deere 345 garden tractor that had a Kawasaki FD590V. That motor blew up so I bought a brand new conversion kit with a Briggs & Stratton 25hp from the folks at Small Engine Warehouse. It matches up perfectly. The wires plugged up fine and everything went together WAY too easy. I emptied the gas tank and even vacuumed out the gas tank to make sure I had good clean fuel. Filled her up and she started right up. The problem is when I put her under a load, she runs for a few minutes and dies. I leave her sit for a few minutes, she fires back up. I can let her sit and idle all day long at both high and low speeds. It only does this when I try to drive the mower. It sounds like a vacume leak but I can find one. Suggestions would be very much appreciated. Thank you
Re: 25hp Intek Briggs & Stratton brand new but dies when under a load. Suggestion? Th
Double check the fuel pump is conneced properly.
Check the operation of the govenor
You can download the Kawakasi service manual but I don't have a link for it that you can access.
Tinkerer200
I can send you a Service Manual for your B&S engine IF you like. Address below, put in proper format and remind me engine model number and what you want.
Walt Conner
wconner5 at frontier dot com
coachcabe
Hey folks, I appreciate the advice. I've checked the fuel, the governor how tight the drive belts are, I'm really at a loss. I decided to video the engine as it starts to die. I thought it would run continuously just idling but I found out it just takes a little longer to die idling. I have posted the link to if anyone would care to take a look and share their thoughts? I'm really stumped. As I said earlier, it's brand new right out of the box.
I appreciate the offer for the service manual but I have that.https://youtu.be/UNl2Jtt8mT4
Tinkerer200
You have checked the gas cap vent? Loosen it, taken it off? Definitely sounds like fuel delivery.
Walt Conner
