I recently did some work on my engine, I had the crank case off, put new gaskets and seals on. I got everything back together and my dad had taken the governor/throttle stuff off and he couldn't remember how it went. When we start it, it will rev really high and I can't control it, I adjusted the cable several times. He thinks governor is stuck open. Anyone have any ideas, maybe a spring in wrong location, he also wasn't sure when we re installed the governor control bracket if the governor should be turned to the left or right, any help would be very helpful.
