25 HP Kohler problems
CptnJack
My mower has roughly 800 hours on the engine. The 25hp Kohler engine is hard to start when cold. It starts fine after it has been warmed up. It is using a quart of oil or more each mowing. It usually taks about 4 hours for each time I mow the lawn.
Any suggestions on the cold starting problem?
And is there an oil treatment that can help with the oil consumption problem?
Thanks
CptnJack
porkchop
Thanks
CptnJack
HHMMMM what kohler model do you have?? Sorry to hear about having a problem.
One, give the carb a good cleaning. Two, make sure that the choke butterfly is closing all the way.
motoman
Captain, way too much oil loss. Is it smoking or puddling when sitting? Engine wet with oil outside? Plugs fouled? Run a quick compression check if you can.
