25 hp kawasaki won't run full throttle after warmup.
And try doing it the other way round
Trim & edge first
That makes the mowing faster & easier
Added bonus is the debris from trimming then gets collected or distributed by the big mower .
stillyoungenuff
That is a very good suggestion I never would have thought of. Thank you very much.
Watch the way the local "opposition" teams do their work
Usually the paid labour does the trimming , edging & hedging then the boss or foreperson does the mowing so they can not only do it faster but check everything has been done properly without having to inspect the job .
Thornback
  • / 25 hp kawasaki won't run full throttle after warmup.
How about rigging a temporary fuel line from portable tank to carb. That would eliminate some parts. My outboard motor on my boat would just die on me at times, but when I pumped the primer bulb it would start and run fine. I borrowed a buddy's portable gas tank and gas line for a test. Outboard still died. I discovered the problem was the snap connection for the gas line at the motor. It was a bad part and resulted in a bad connection thus at times allowing air to be sucked in.
Also if the valve gap is too close then when the mower is shut off it temporarily heats up because it's not being air cooled. This closes the gap even more and effects the valve timing which can result in a loss of power when the mower is re-started.
Make sure the coil is good and the spark plugs are good ones with the proper gap. I had a Dixie Chopper once that ran fine down a grade but skipped going up the grade. That was a strange problem to diagnose. Found the coil wire insulation was rubbed off where the wire passed through the frame. Naturally the spark took the path of least resistance and intermittently grounded out when the mower was under strain going up hill.
I had a chain saw that would start fine but the instant I tried to cut with it it would bog down. I purchased the most expensive spark plug I could find and that solved my problem.
Are you sure the carb is getting to wide open throttle? Entire Kawi linkage conglomerate could be off. Seen it many times.
Use your finger to manipulate the throttle plate. See if you can get more revs when it bogs down.
Try changing spark plugs. Could have a random nut job in there doing intermittent games on you. Look for plug wires getting shorted to ground.
