Ericci85
Hello all,
New to the small engine repair world. I have a Husqvarna YTH22V46 with Briggs Twin engine. Noticed hard running at full or high throttle during last cut. Normal running while at mid to low throttle. Let it cool and tried to start up again and noticed bit of white smoke at start up.
Checked the spark plugs and valves. Both plugs burnt black and fuel side plug had oil on it. Pulled valve covers and found oil in exhaust side. I'm speculating this is not normal and likely the result of a blown gasket. Assuming it would be the head gasket. I've watched the videos seems straightforward a repair. Just wanna make sure I'm not overlooking something else? Also, if anyone knows the easiest way to check the timing on these engines I'd appreciate the info, thanks!
Ericci
Ericci
