I bought a 22 year old troy bilt bronco 22 hp vtwin b&s with a vari drive I think it's called, I'm waiting for a carb, in the meantime I checked out the drive......
i have Forward low high and reverse but the only way to stop is to throw it out of gear.....the clutch will not slack up on the belt enough to stop it
the peddle has only about a half in. play in full down, the belt is hot and never stops, not enough slack on the pulleys.....I can't see any adjustment on the clutch pulley, it can't move one way or the other very much......
if I had to guess I would say that the belt is too short, because there is so little travel in the peddle... let me know if that is a good guess.......if not I'm hear to learn........I did't study it too long, I had to have break from the heat...........thanks for any ideas
