22" kohler High Wheel model 20378
Pugetsoundwa
Hey, just bought one about 3 days ago and only used once.
Moved from a neuton as its batteries no longer wanted to hold a charge.
Figured at the price Home Depot wanted even if it just lasts the warranty I got its money's worth.
Grass was a bit tall and a bit wet so I am cutting my first experience a bit of slack. What I mean is it did get a bit load under the deck as I didn't use a bag or discharge. Also self propelled spun out a bit.
I am hoping at one cutting a week, grass cut to 3 1/4 in, that the next cut will be better.
I will say it does recycle good. Much finer clippings left then before.
Do others own one? There are mixed reviews online.
The engine on the Toro mower you bought is only 150cc. I have a Honda mower that has a 190cc engine, and there are Toro mowers that have 190cc engines, too. You might want to look into those.
Good luck and let us know what you decide to do. :smile:
Mulching wet and long grass will be hard on the engine. Always try to cut when it is dry and cut not more than a third of the grass height to get the best results.
