- Feb 19, 2020
- 120
- 12,817
Lower end is in place and the upper end is nearly impossible to become dislodge due to the Z end. Normally it would require removing the intake manifold.
Have you adjusted the cable per the instructions given making sure the choke closes? Loosen the cable housing clamp. The D wheel [swivel] must all the way CCW with throttle lever at Full before tighten the clamp on the cable housing. Some resistance will felt as the choke lever moves choke vane to fully closed.
