You need to provide us with the engine model and type number information that is stamped into the rocker cover on the engine.Thank you all very much for the answers. I learn a lot here. as someone said the problem is in the choke. I wanted to attacha video but i can't, is possible to send a video?
no, the throttle cable is working okWas the throttle cable takes off of this at some point?
The engine part of the photo rotates.IF this don't move [rotate].
But the inner extends and retracts then the cable clamp is probably missing or loose.
thanks!Removed the air cleaner and backing to see the actual choke plate. You may have to pull the entire upper fan shroud off. The linkage rod that operated the choke may have popped out of the clip at the bottom or top.
Take a couple of pictures from about a foot away when you get it apart.
