Alan46
You guys should get a room!
Search this forum for the thread:I just picked up a Craftsman LT1000 with a 21HP Briggs V-Twin, model number 407577-0283-E1. I believe it needs new head gaskets, I have ordered the gasket kits but I was just wondering if I need to order new head bolts too? In the past I have ran into issues reusing head bolts and them snapping in the block while torquing them down. I was also wondering what the torque specs are for the head bolts, and how many stages I should torque them down and how many foot pounds for each stage. Iโm 18 and fairly new to this, so any help would be appreciated.
Probably over torqued if you broke them. On these little engines you set the torque in your elbow. Usually around 225 inch Lbs. Divide that by 12 to get ft lbs or 18.75 ft lbs. That becomes 18.75 lbs on a 12 inch lever. That is not much! estimate by picking up 2 1/2 gallons of water in a bucket ( Water is 8 lbs/gal). That's how pull you have to put on a 12 inch wrench handle. Use a criss/cross pattern a little at a time. On truck lug nuts that require 150 ft/lbs, use the lug nut wrench and step on the handle. If you weigh 150 lbs your on. If you weigh 200, add about 3/4 th of you weight.. Now, when you are done try to turn it a little more with you cross wrench. If you make it turn a little feel the force with your arms. You'll figure it out.I just picked up a Craftsman LT1000 with a 21HP Briggs V-Twin, model number 407577-0283-E1. I believe it needs new head gaskets, I have ordered the gasket kits but I was just wondering if I need to order new head bolts too? In the past I have ran into issues reusing head bolts and them snapping in the block while torquing them down. I was also wondering what the torque specs are for the head bolts, and how many stages I should torque them down and how many foot pounds for each stage. Iโm 18 and fairly new to this, so any help would be appreciated.
Head bolts are often brittle after they become 'work hardened'- he's not inexperienced in general, just with these engines, which don't require much torque.Probably over torqued if you broke them. On these little engines you set the torque in your elbow. Usually around 225 inch Lbs. Divide that by 12 to get ft lbs or 18.75 ft lbs. That becomes 18.75 lbs on a 12 inch lever. That is not much! estimate by picking up 2 1/2 gallons of water in a bucket ( Water is 8 lbs/gal). That's how pull you have to put on a 12 inch wrench handle. Use a criss/cross pattern a little at a time. On truck lug nuts that require 150 ft/lbs, use the lug nut wrench and step on the handle. If you weigh 150 lbs your on. If you weigh 200, add about 3/4 th of you weight.. Now, when you are done try to turn it a little more with you cross wrench. If you make it turn a little feel the force with your arms. You'll figure it out.
