2135 Cub Cadet Kohler Engine not starting after engine is warmed up
LoriC
have a 2135 cub Cadet w/Kohler Engine that will not start if stopped then started again within minutes. No Spark...until engine cools down? Any insight? Thoughts? Thanks
Sounds like a bad coil.
(( racing is the only sport that you need two balls ))
