2135 Cub Cadet Kohler Engine not starting after engine is warmed up
LoriC
have a 2135 cub Cadet w/Kohler Engine that will not start if stopped then started again within minutes. No Spark...until engine cools down? Any insight? Thoughts? Thanks
To get he help you need giving the model number will be needed. Not all engines are the same.
Sounds like a bad coil.
