2135 - Check the rear wheel lug nuts!
packardv8
I was doing the annual spring cleaning; new air filter, oil and filter change, lubrication, check tire air pressure. This time, I happened to notice the left rear lug nuts were loose. I'd have thought I'd have noticed if they were loose last year, but who knows?
jack vines
mechanic mark
Good eye & post Jack Vines, preventive maintenance keeps them running.
reynoldston
. Wheel nuts should be tighten with a toque wrench. Me not knowing the size I can't give you the specs. Then after you run the mower lets say after a couple of lawn cuttings they should be checked again. I have found as a rule after the second tighten they be good to go.
