bkeller500
- Jul 2, 2018
- Threads
- 7
- 309
I have owned a Simplicity, Broadmoor, Conquest, Courier and now a Courier XT, all of them had the deck rollers for striping. Never once has any of them had a issue with collecting buildup on those rollers that eventually caused the rollers to skid or slide instead of rolling. Yes it can build up with very wet grass or if you mow in the rain, but the rollers have never been skidding or tearing the grass. I guess it could happen but in my experience ...never!Wow, great information. The one area I see that is mentioned more than a few times from user reviews is when mowing wet or longer grass the roller bar on the deck can get clogged fairly easy resulting in the bar not rolling but rather tearing your lawn?? Has anyone experienced this?
Thanks, Ken
I have caught the roller on a root a few times and once had bent the shaft, but that was easily fixed. Simplicity has changed the way the decks are mounted. Previously they hooked on a front mounting block and the decks followed the tractors while riding on the rear deck rollers. They now suspend the decks via chains on some models and that takes the weight off that rear deck roller. It still rolls the grass over but now it's 1/2" -1" higher than the ground and isn't supposed to ride on the ground. Talk to you dealer and he can show you what I am referring to.
