bkeller500
- Jul 2, 2018
- Threads
- 7
- 311
is the deck level side to-side? Is it pitched front-to-back? Look at your manual for proper level and pitch instructions.....it may help. Also double check the air in the tires and set to factory specs. You may just need some tweaking. Or perhaps a different blade with a higher lift.I bought a MZ Magnum late last summer. If the grass is more than a few inches tall. The mower leaves two strips down the center. Looking at the blades. I don't understand why Bad Boy didn't move the middle blade spindle further forward and the two outside spindles in so the three blades would overlap slightly. Instead they left about a 3/8 gap between blades for grass to slip through. Other than that it's a good heavy made mower.
