troybam
hope someone can help! i have a 2019 bad boy maverick , with a 747 kohler, while backing up i had a large limb hit the throttle cable linkage on the back of the motor. it pulled the coating off the throttle cable about 2 in.. i did reattach the cable but now the motor is not running the same RPM's. its only running 3040 rpm. Does anyone know the correct way to reset the throttle linkage and what RPM should the 747 be running without the blades engaged.
