Mower doesn't run have spark what are the timing marks are they still dot to dot
B BOB'S small engines Forum Newbie Joined Sep 28, 2020 Threads 1 Messages 7 Sep 28, 2020 / 2018 murray mower with 4.50 e series #1 Mower doesn't run have spark what are the timing marks are they still dot to dot
Scrubcadet10 Moderator Staff member Joined Sep 24, 2017 Threads 277 Messages 6,741 Sep 28, 2020 / 2018 murray mower with 4.50 e series #2 they should be dot to dot still, Did you check the flywheel key? what the engine model number?
B BOB'S small engines Forum Newbie Joined Sep 28, 2020 Threads 1 Messages 7 Sep 28, 2020 / 2018 murray mower with 4.50 e series #3 I have the timing marks set at. The. The flywheel key is fine I had the engine apart everything looks good Highmark set dr. It has the plastic cam
B BOB'S small engines Forum Newbie Joined Sep 28, 2020 Threads 1 Messages 7 Sep 28, 2020 / 2018 murray mower with 4.50 e series #4 When I try to start it I heard some mild popping through the car it has plenty of spark I checked the Piston the Piston is fine
tom3 Lawn Addict Joined Apr 9, 2018 Threads 25 Messages 1,579 Sep 28, 2020 / 2018 murray mower with 4.50 e series #5 Is this an overhead valve motor?
B BOB'S small engines Forum Newbie Joined Sep 28, 2020 Threads 1 Messages 7 Sep 29, 2020 / 2018 murray mower with 4.50 e series #6 Yes overhead value I checked the clearance is st at 6 on in tr make and exhaust
tom3 Lawn Addict Joined Apr 9, 2018 Threads 25 Messages 1,579 Sep 29, 2020 / 2018 murray mower with 4.50 e series #7 This is a pretty dumb question, but is it possible to put the coil on upside down, way early ignition?
Scrubcadet10 Moderator Staff member Joined Sep 24, 2017 Threads 277 Messages 6,741 Sep 29, 2020 / 2018 murray mower with 4.50 e series #8 It is possible for the coil to be on upside down. Try flipping the coil over.
B BOB'S small engines Forum Newbie Joined Sep 28, 2020 Threads 1 Messages 7 Sep 29, 2020 / 2018 murray mower with 4.50 e series #9 I'm 100% positive coil is correct , my cam has the compressing release on it and working properly but hard to get proper compressing reading
Scrubcadet10 Moderator Staff member Joined Sep 24, 2017 Threads 277 Messages 6,741 Sep 29, 2020 / 2018 murray mower with 4.50 e series #10 People have said that before too, and turns out the coil was on upside down.
