2018 murray mower with 4.50 e series
BOB'S small engines
Mower doesn't run have spark what are the timing marks are they still dot to dot
Scrubcadet10
Moderator
Staff member
they should be dot to dot still, Did you check the flywheel key?
what the engine model number?
BOB'S small engines
I have the timing marks set at. The. The flywheel key is fine I had the engine apart everything looks good Highmark set dr. It has the plastic cam
BOB'S small engines
When I try to start it I heard some mild popping through the car it has plenty of spark I checked the Piston the Piston is fine
tom3
Is this an overhead valve motor?
BOB'S small engines
Yes overhead value I checked the clearance is st at 6 on in tr make and exhaust
tom3
This is a pretty dumb question, but is it possible to put the coil on upside down, way early ignition?
Scrubcadet10
Moderator
Staff member
It is possible for the coil to be on upside down.
Try flipping the coil over.
BOB'S small engines
I'm 100% positive coil is correct , my cam has the compressing release on it and working properly but hard to get proper compressing reading
Scrubcadet10
Moderator
Staff member
People have said that before too, and turns out the coil was on upside down.
