2017 bad boy kawasakit motor blew a hole in the block
krackerjack9
ok kawasaki motor 122 hrs bought it new in 2019 FR691 motor so didnt use to much but we finally got some rain and been using it some this year but it always went thru a qt of oil about every 2hrs, well today it started up then it sounded funny and noticed black oil all over sure enough a hole in the block by the oil fill tube so looking at getting another engine BS 2700CXI 27hp engine pretty sure the engine mounting holes are the same but is the PTO Clutch assembly the same?? looks from what i see is that their a universail type of design the shaft is the same but its 1in so it wont work so i would need a 1 1/8 pto clutch correct for the CXI2700
Kawasaki makes a great engine. If your Kawasaki FR was burning 1 quart every 2 hours, at only 122 hours on the meter, that is crazy. Probably cracked the engine case from a broken connecting rod, due to running on very low oil.
Engine holds about 1.75 quarts of oil total.
Sounds like someone that was afraid to receive a repair bill to me. Now it is costing a lot more like one of my customers that had a blown head gasket on his PU that was leaking water. I got the leak temporary stop and told him get the engine repaired. But he didn't, now its is a new engine or a major rebuild provided he didn't crack his block when the cold water was added to an overheated engine.
As the engine here probably had a blown head gasket like the FT1000 I had in the shop a couple years ago. It had lots of power but was going thru oil like crazy; no smoke or oil leak. In this case sounds like the OP finally ran the engine too low and started the death spiral where a rod breaks and holes the crankcase.
I always wondered what was inside the engine that made all that power when I was a kid. As an early teenager I figured it out when I neglected to check the oil a couple of times.
After that I got really good at engine maintenance and repairs as needed before they became a catastrophic failure.
Everything was a bit of a mystery as to how an engine worked for me for many years. That was part of the reason I wanted to learn. It isn’t just engines, it is mechanical things, common sense, practical applications. Etc. that interest me. Now, it mostly all makes sense. These folks that think you can watch a couple of YouTube videos and have it all figured out are funny.
