2017 bad boy kawasakit motor blew a hole in the block
krackerjack9
ok kawasaki motor 122 hrs bought it new in 2019 FR691 motor so didnt use to much but we finally got some rain and been using it some this year but it always went thru a qt of oil about every 2hrs, well today it started up then it sounded funny and noticed black oil all over sure enough a hole in the block by the oil fill tube so looking at getting another engine BS 2700CXI 27hp engine pretty sure the engine mounting holes are the same but is the PTO Clutch assembly the same?? looks from what i see is that their a universail type of design the shaft is the same but its 1in so it wont work so i would need a 1 1/8 pto clutch correct for the CXI2700
