2017 bad boy kawasakit motor blew a hole in the block
A hole in the block is caused by to much power it needs a way out.
Benefits, easy oil changes, an easy look see at how an engine works, no more stale air in the crankcase, depending on size no need to remove pan to check rod bolt torque.
Down side: usually caused by a connecting rod wanting out, leaks oil, may structurally weaken block, have seen some that have broken the starter. Only one cylinder left to do the work. Low power.
Cause usually run low of oil causing the aluminum rod to weld to the crank, since it is welded fast it wants to go with the crankshaft. Also possibility of a bad rod casting or a crack.
Sounds like OP did not repair oil usage, left it run low, and the rod welded to the crank, presto, magic hole.
As for what fits as a replacement need to review the specs on both engines. Most will bolt up but the C/S diameter and length need to be the same, wiring may needs some changes, frame my need modified for oil filter clearance,
By search the web especially manufacturers and small engine sales sites the crankshafts can be checked for size. BUT you must use the engine number NOT the emissionns labels
Kawasaki ususally used a paste on sticker that reads:
model spec
FR691V-AS02- serial number
Sometimes these stickers get pressure washer or just plain fall off.
Briggs usually stamped in the valve cover or block and reads
model spec
44L997-0134- serial number
Both of the model numbers indicate series, size, or C/S position H or V.
The second set is the recipe of parts that make up that engine
Such as air cleaner, carburetor, C/S diameter and length, type and size of charging system, and any special requirement request for their application.
