Silverdillo54
- Jan 3, 2026
- 2
I have a 2016 Ferris is 600z with the B&S 25 hp commercial. I’ve replaced the battery and solenoid checks out. I’m only getting about 9 volts at the starter but have a strong 12v at the solenoid with the starter cable removed. Do you have to remove the motor to replace it? I can’t see or touch any mounting bolts under the sheet metal shield holding the starter.
