2016 BB Outlaw w FX730V Kawasaki will not crank w/o charger or jump
  • / 2016 BB Outlaw w FX730V Kawasaki will not crank w/o charger or jump
In AC they go both ways
Having a charge of -1eV by definition they have to go from negative to positive
But saying some thing goes from what we designate as being 0 to some thing that we designate as being more than 0 contravines the laws of thermodynamics
So to make things right with our feebel little brains we defined Current ( amps ) to travel in the opposite direction + to -.
hlw49
Thank you Gentlemen for the advice. I cleaned battery cables at both ends. not sure where to find the ground strap. Checked owners manual no luck. Should that be running from the starter? Perhaps I need to just start replacing wires. before do that I'm going to have a buddy load test the Battey "again".
A lot of mowers do not have a ground strap. They just ground through the engine mounting bolts and ground the negative cable to the frame. That would be a good reason to run a ground strap from the engine to the negative battery post and make sure the ground from the negative battery post to the frame makes a good connection.
reported
