PVHIII
- Jun 13, 2013
- 15
- 289
Sounds like B-S to me. Brand new mowers shouldn't back fire they need to fix the exhaust then. That's my feelings on it , if it were my mower , no way I'd accept it. Call Hustler direct also. Long term they cause damage ... igf they tell you to shut it off at half throttle then it shouldn't back fire , period.
If commercial guys accept it doesn't make it ok. I'd try some different fuels or additives. Maybe some none ethanol stuff. I had a 17hp B&S that back fired I switched to 91 it stopped. For me its beats bent valves. I'd also keep making sure you document it when calling use emails so you can get it on paper.
My manual says low idle shut off blades , then run a couple minutes then shut off. Not half throttle. I own a different engine though.
Call Hustler , no results call Kawasaki......ask Hustler on facebook or twitter I always get better results when its public. :wink:
I would have to agree with Tom if it's backfiring you have a problem that needs to be addressed
