2012 LTX 1040
Kor b
Hi all
I'm a new member and want to defeat all safety switches at a point other than the switches at the source. Is there a place in the wire harness that i can do this?
For testing only.
WHY ?
If you have a particular problem we will be happy to help you work through it.
If you do not have the required skills & interlect to work out how to bypass them I would suggest you do not have the required skill & interlect to use the mower safely without them.
One set protects the mower and the other set protects to operator & BYSTANDERS .
If you insist that you have to follow this path then there are thousands of redneck morons with substantially lower brain function than average on U-tube showing people of a similar vein how to strike a blow for freedom from oppresion and the American Way by bypaassing stuff that got put there to stop idiots with less than 2 functioning brain cells shoving their hands into a clogged deck chute and loosing the finger they pick their noses with.
Kor b
WHY ?
You really should get better at spelling before you insult my intelligence. Lol
shiftsuper175607
He can spell fine...he's just from Australia...they use different words "down under"
Especially when typing in a hurry.
NorthBama
Bert is a very intelligent person he just tells it like it is. :laughing: :thumbsup:
Russ2251
We really do not need this kind of negativity. It's a lawnmower forum...nothing else.
Get a grip kids.
Darryl G
The OP did say for testing only. On my Kawasaki engines there's 1 black wire down low on the side of the engine I unplug. Need to reconnect to turn mower off.
The OP did say for testing only. On my Kawasaki engines there's 1black wire down low on the side of the engine I unplug. Need to reconnect to turn mower off.
Ooops did not read the second line.
Humble hat on standing in naughty corner eating crwo
