WHY ?
If you have a particular problem we will be happy to help you work through it.
If you do not have the required skills & interlect to work out how to bypass them I would suggest you do not have the required skill & interlect to use the mower safely without them.
One set protects the mower and the other set protects to operator & BYSTANDERS .
If you insist that you have to follow this path then there are thousands of redneck morons with substantially lower brain function than average on U-tube showing people of a similar vein how to strike a blow for freedom from oppresion and the American Way by bypaassing stuff that got put there to stop idiots with less than 2 functioning brain cells shoving their hands into a clogged deck chute and loosing the finger they pick their noses with.
