On the pump all HG offers in kit format is overhaul seal kit.
Now the they offer both a seal kit and a bearing kit.
As the rear wheel cambering it can one or more problems. Bad bearings or frame damage is a couple possibles. I work on a Scag last year where the frame around the wheel had been weld up. And it probably the reason someone didn't torque the hub nut back to spec as they most likely removed the wheel motor to do welding. Of course this cause axle key to shear and ruined both the hub and axle; requiring both to be replaced. Even the frame can twisted but if that is the case you can shim the wheel to return the wheel camber back to zero degrees.
Pump seal kit is PN 70525 Available. IT just my vendor don't have it in stock
Wheel motor seal kit PN 7602-3 NLA
Wheel bearing kit PN 71494 NLA
