bijiminy
- Aug 17, 2020
- 11
- 50
I have been running Castrol 10w30 in this engine on the advice of the local Dixie Chopper Dealer, even though Dixie Chopper recommends Lucas 15w40 specifically for this engine. He had previously serviced this engine with 10w30. I was amazed this dealer had never heard of a Generac engine in a Dixie Chopper. He assured me 10w30 would not hurt the engine. Recently the temperature outside has reached near 100 degrees and the oil pressure warning light started going on and off. I'm hearing no clattering, the engine does not shut down though I don't think this mower has this feature. The engine is not low on oil and the oil is still clean. The engine has just turned 600 hours. I added just a little more oil since I was running 2.0 quarts, to just get it to the full mark, instead of 2.4. It is now above the full mark. It didn't make any difference. Light is still flashing. The engine runs very well. I'm not hearing any strange noises, starts on first turn, which make me think I possibly have a oil pressure switch problem and maybe I should be running the recommended 15w40. I ordered a gallon of the Lucas 15w40 oil and a new switch. Should I worry that I have harmed my engine from bad advice or what? Is my thinking correct on this? Thanks for any advice..
