2004 TroyBilt Bronco 18.5 HP B&S Stalling!
EngineMan
I thought I wasn't going nut's, getting old yes....!
Firebirdman469
Does anyone have a write-up on how to check/adjust valves? I want to make sure that isn't the issue...or at least AN issue. Thanks!
EngineMan
You need to post up the model number. (engine number)
EngineMan
Most B&S valves can be adjusted at .003 on both.(cold) some people set them at Intake .004 and exhaust .006
Turn the crankshaft until exhaust valve is at its highest position, then check clearance on the intake valve, then turn crankshaft until intake valve is at its highest position, and check exhaust vale clearance.
The valves should actually be adjusted to spec every 12 to 18 months.
Read more: I have a briggs and stratton 31p777. It has hard starting issues. - JustAnswer http://www.justanswer.com/small-eng...1p777-hard-starting-issues.html#ixzz20PoPwMyS
Have a look at this video...it may help you a little...!
http://youtu.be/NjzX-PUjKmo
Firebirdman469
Read more: I have a briggs and stratton 31p777. It has hard starting issues. - JustAnswer I have a briggs and stratton 31p777. It has hard starting issues. - JustAnswer
Lawn Mower Repair Valve Adjustment - YouTube
Thank you so much for your help! I recleaned the carb, installed the rebuild kit, adjusted the valves and it purrs now! I couldn't be happier! Thanks again!
EngineMan
Well done and job done:thumbsup:
