Reubenjet
- Jun 29, 2017
- 30
My 225 is having an issue where it takes the blades longer and longer to engage after pulling the PTO switch. I am also having to charge the battery after every 4 or 5 hours of use. Is the PTO issue caused by the battery not being charged? The mower will run all day along with the blades going but if I ever shut the blades off then cut them back on it takes over 10 seconds for them to engage. Also, if I ever cut the mower off after 4 or 5 hours it will not start back up.
I am not very mechanically inclined so if you can help explain what may be the problem and how to fix it in detail I would appreciate it. Also, I am not one to take my mower to the shop if it is something I can fix myself.
Any advice is appreciated!
