macec3(TX)
- Apr 24, 2017
- 2
- 9
Dixie Chopper will not crank at all. Cleaned battery terminals on both cables. Checked continuity of both battery cables. Checked key switch. Had starter rebuilt with new solenoid. Checked fuse. Connected to new battery. By passed the shut down switch in the seat.
When key is turned 1 click the oil pressure alarm sounds. When the key is moved to the spring loaded start position, nothing. No sound, no smoke, no sparks, nothing at all. I am not very knowledgeable about electrical systems. Any help or advice would be appreciated.
Thanks.
Thanks.
