basstracker
- Jul 9, 2013
- 51
Hello everone, need some help. I got this mower from a frend. He could'nt keep the drive belt on. He took the mower all apart and found the verable speed pulley was wore out, and the hole where the pulley fastened was wallowed out. I drilled the hole bigger and put a bushing in it. I found a good used verable speed pulley that was in great shape.Everthing fit good so I put two new mtd drive belts on it. The problem is it only goes slow, It won't speed up when I press the foot padel.
