2000 Lazer Z faulty Left control arm safety switch.
DeanSanders
I'm an old dude and need to bypass this switch to get it to started so as to drive it up a trailer ramp. I don't have a way to do otherwise. Any help would be greatly appreciated. Thanks
It is a simple make or break switch so either you jump the wires or disconnect the switch all together.
If it is a 4 pin switch, one pair will need to be open & the other closed .
And they connect flat to flat inside the switch.
