Michael72
Here what I know for sure. Model 61707 Type 0145 E3 Code 9912205A I definitely leaking from the crank shaft seal underneath. Smoked for a while this morning blades weren't spiinning too fast just kind of died in the grass. Motor kept running though. Last year all was well it just was using a lot of oil. This year I have had it out for about a month now I its getting weaker. I also know its using almost twice the fuel. All I have is a standard compression gauge. I'm tempted to take it apart. Its not in the cards for a new tractor this year. Right now I'm all ears.:smile:
Hows those head gaskets??...you will lose power there too if gaskets are bye bye...it smoking all the time but stronger on start up?...
