I just bought my first 2 stroke echo trimmer. I have used it quite a bit and now, when I try to start it or when it starts sometimes, it sputters and either shuts down or makes me work the throttle until I achieve proper rpm.
The unit is 4 months old but is used extensively throughout the work week. Thanks for the feedback!Now it will depend upon how new this model is. There are 3 adjustments on diaphram carbs. High speed fuel needle Low speed fuel needle Idle throttle opening. If yours runs fine at full speed but just has trouble getting there then 99% chance the low speed jet is clogged. Take a couple of photos of the carb & post them so we can work out what carb you have on there to give ou proper instructions.
