2 stroke engine (filter/exhaust leak)
But most are too lazy to learn and somebody else can do it for them.
Staccato
Thankyou all for the help. I pressed the bulb and one of them pushed air out indicating the outake (the one marked green in my picture attached). The other one would create some slight suction when bulb was released which indicated the intake. So I think I've got this right!
Here's a picture of the corroded fuel filter
Staccato
Replaced carb and fuel filter with fuel lines, tested spark, checked and petrol getting into the primer bulb no probs. Ofcourse did the fuel mix thing 100% correct this time round. Still sounds as dead as ever upon starting. Made sure choke was set on cold when starting along with all the other checks still NOTHING :rolleyes:
Was attempting to add some 2 stroke into the engine directly when i accidentally ripped open the spark plug housing the spring came out. So that's another issue. Does it sound like there's any hope?? lol
Or should I just purchase one
