tigercat
- Nov 17, 2012
- Threads
- 19
- 280
On the machine on the left , are those two brackets ( ? ) in front of the handlebar housing for a snow cab ?
Also , how did you mount your lights ? I doubt the one on my platinum housing isn't going to work well when I put a cab on it.
Hi Phil
Yes I put a snow cab on the bigger 30" machine. It's the platinum 30" with a 12 HP Briggs engine. The snow cab will be used for the first time this year, when I get the cold January blown snow, then I will try it out. The cab was a bit of a pain in the neck as I needed to weld the brackets (of the snow cab) to reinforce it so it won't drop on my head as I was testing it out. I think it will work well now, and it pulls off with a simple wing nut on each side.
The brackets on the machine are drift cutters. I used them last year so I ordered weights and the drift cutters for the 28" machine yesterday. The weights fit under the shovel and they weigh 10 LBS. It bolts on by pre existing holes stamped into the blower housing. It helps hold the machine down so the packed snow won't push up the machine as I travel around the walks.
The 28" machine is my spare machine if something happens, I won't be SOL. I have way too much walks to tend and I rather have a spare and service the machine the next day if something breaks down. So far knock on wood, the Ariens 30" machine is a tank with no issues yet.
The Ariens built in light I hate. As I walk around blowing snow, the light shines right into my eyes. (I'm 6' tall) So I went to Northern Hydraulics website and ordered lights for 20 bucks a piece and wired them up, with it own switches (one switch per light). I removed the existing light and sanded the plastic lens down, then painted it black. I mounted the "new" lights around the dash so it fits nice. The new lights throw light like the old tractors of years ago. Awesome improvement!
No worries on the electrical system as the new Polar Force engines put out enough electrical power, so even with both lights and hand warmers on the lights still shine brightly.
I added my own "roller shoes" on these machines to help out on wear from the cement sidewalks destroying the standard skids on the snowblowers. Now the bearings simply roll down my walks. The skid plate don't need to be adjusted any longer so the snow is always scraped just right down the walks...
Here are the pics.
On youtube I made a short movie how the roller shoes work.
http://youtu.be/VG1giQ0heaY
