Ronno6
- Apr 8, 2016
- 24
- 1,933
I still seek ideas on the constant necessity of choking to start....even when warm.
I have postulated the theory that, as the jet O-rings do not hold the jets in place and allow them to drop down til the plastic shutoff solenoid sleeve stops them from falling out completely, the fuel can circumvent the jet orifices.
Doe to lower engine vacuum thru the carb generated at low starting RPMs, there is not enough suction to pull the fuel up thru the transfer tube and allow the engine to start. Kind of akin to drawing liquid up thru a hose vs a straw. The straw is much easier.........
I will see if this condition improves after installing new jet O-rings.
