Replaced oil filter and breather.... runs 10 minutes, blows oil.
S Snipehunter Member Joined Jul 9, 2012 Threads 1 Messages 15 Jul 14, 2012 / 1st post. Briggs 24hp 4460777 0302 (twin) loosing oil under the fly wheel? #21 Replaced oil filter and breather.... runs 10 minutes, blows oil.
S Snipehunter Member Joined Jul 9, 2012 Threads 1 Messages 15 Jul 14, 2012 / 1st post. Briggs 24hp 4460777 0302 (twin) loosing oil under the fly wheel? #22 Snipehunter said: Replaced oil filter and breather.... runs 10 minutes, blows oil. Click to expand... The seal. Seated flush against the casing or should it be lower.. pressed down into the casing. The old one was flush so that's how I did the new one. . Should it have been flush or set-in?
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 62 Messages 15,745 Jul 14, 2012 / 1st post. Briggs 24hp 4460777 0302 (twin) loosing oil under the fly wheel? #23 This web site explains it better than I can. How Small Engine Breathers Work | eHow.com So will this one. http://www.g-w.com/PDF/SampChap/60525_5475_CH13.pdf
S Snipehunter Member Joined Jul 9, 2012 Threads 1 Messages 15 Jul 16, 2012 / 1st post. Briggs 24hp 4460777 0302 (twin) loosing oil under the fly wheel? #24 Found a crack in the casing near the upper seal yesterday. I guess I could have rebuilt it but with close to 700 hours... I bought a new mower. Thank you for all the help
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 62 Messages 15,745 Jul 16, 2012 / 1st post. Briggs 24hp 4460777 0302 (twin) loosing oil under the fly wheel? #25 That's a new one for me. Learn something new every day. Good luck with your new mower.
