1999 MTD 13au694h088 transmission Fluid
N5WXB
Trying to remove the Drive wheel using puller and mallet, it did come off but axle came off too. Axle is back on and secure but need to refill fluid. Question is how much and what type?
81 ounces of 20W50 motor oil. spin the input shaft with a drill while performing the air purge procedure before reinstalling the unit. Oil level should be around 1.5-2 inches from the top after purging.
N5WXB
Thanks for the information, The fluid that came out was gray in color and flowed very slow. I', guessing that only 2/3 of a qt. leaked. I'm wondering if you know how can I remove the rest and fill all with new. Again, Thank you for the information!
Best you can do is remove the unit from the mower and turn it upside down with the vent/fill plug removed and drain as much as possible. Fill within 2 inches of the top and then air purge it and then check the oil level through the fill hole. Adjust level as needed.
Personally with the oil coming out grey mud I would split the case and clean or change the internal filter as it sounds like water has gotten into the unit.
N5WXB
I roger that, Bought it 5 years ago been changing belts, pulleys and engine oil regularly. My guess is Tranny fluid is 25 years old... Runs great, I'm kicking my *** thinking I should have just got a tube for the tire instead of trying to change it. A lot less $$$ and a boat load more time and aggravation. Oh well. Thanks bud.
N5WXB
Well, it's 4 months later and the Mower is running just perfect however yesterday I had an issue where my left rear axle slipped out. I jacked it up and hit it back in only to have it come back out about 15 minutes later. Is there a pin or C clip missing? Any advice is muchly appreciated. Thanks in advance for your time. Brian
It lost the retaining ring but a replacement is not listed in the parts list. But even the complete differential set is NLA.
Hydro 310-0650 Series. Items 49 is the axle shaft retaining rings.
hlw49
If it is part no.44871 Medart has 141 of them in ware house 08
hlw49
How did you get the axle back in the first time without splitting the case? If you did it like it should have been done you could have change the fluid then.
