1999 Husqvana LTH130 42 inch deck extension spring install
Fred_T
  • / 1999 Husqvana LTH130 42 inch deck extension spring install
I'm looking for help on how to install an extension spring on the clutch pully. The spring broke in half. From whats left of the spring, one end attaches below the bolt on the pully itself. I have a new spring but can't for the life of me figure out where the other end goes. I have a possible location but it does not feel right. Any help or pictures of an actual set up would be great. The parts diagram in the manual is useless...Thanks, Fred T
Get a strong torch and look at all of the possible mounting places
One will be shinny where the spring was hooked in and usually the hole will be keyholed or a bolt will have an under cut from wear .
Fred_T
Thanks for the suggestion, I’ll look for a shiny keyhole…
Fred_T
All set, figured it out. The other end of the spring hooks to the clip on a mount at the back of the deck.
Thanks very much!
Thanks for the heads up.
Enjoy your mowing season
