1994 craftsman
Having problem with craftsman when it gets hot. The battery drains and the mower deck kills the engine when I use the PTO to engage it.When I disconnect the regulator connector the deck and motor runs fine,but I cannot kill the engine with the ignition switch. Then when I connect the regulator/rectifier while running it kills the engine. Any ideas would help thanks.
